- Forum-Beiträge: 1.679
09.04.2012, 01:07:05 via Website
09.04.2012 01:07:05 via Website
der Entwickler imilka hat soeben die Cyanogenmod 9 Rom fürs Galaxy Note portiert.
Bei dieser Version handelt es sich um eine inoffizielle Version, heißt, sie wird nicht vom Cyanogenmod Team supportet, sondern von imilka selbst.
Die Rom hat nur zwei oder drei (kleinere) Bugs, so wies aussieht.
This is UNOFFICIAL CM9 build compiled using galaxys2 branch
This build IS NOT SUPPORTED by CyanogenMod team
Please, do not ask anything or report bugs directly to CM9 team members, they're not responsible for that - report anything you will find to me
This is just clean CM9 build made for those users who like it and will be maintaned by me at least until Note will be officially supported.
imilka's CyanogenMod 9 v01
Well, sorry, but I'm not going to talk much about features etc
I hope you already know what CM9 can offer.
And I haven't made any major modifications except some resolution adjustments.
Known bugs:
Basically, it works better than AOSP does right now.
WARNING: External SD Card is mounted at /mnt/emmc!
•FM Radio: not implemented
•TV Out: not working properly
•Phone Encryption: not working
Installation:
1.
a) if you're on any other build except AOSP based ones: flash Chainfire ICS repack using mobile odin
b) if you're on AOSP based build or previous CM9 version: do nothing
2. Upload cm9gnXX.zip into your sdcard
3. Reboot into recovery
4. Flash cm9gnXX.zip
5.
a) if you was on CM9 previous versions and want to keep your data: do nothing
b) if you was on any other build: wipe data using CWM recovery
6. Reboot and wait
Download:
http://download.imilka.eu
Latest Google Apps: http://goo.im/gapps
v01 additional files:
Tablet mode enable zip - http://dev.imilka.eu/cm9/tabletenable.zip
Tablet mode disable zip - http://dev.imilka.eu/cm9/tabletdisable.zip
Some more coming soon.
Changelog:
*placeholder*
Thanks for
1) each person involved in CyanogenMod development and galaxys2 device maintainers
2) each person credited in my AOSP thread
— geändert am 09.04.2012, 01:14:01
Unsere Internetseite www.youngsider.de
