input und output mit socket und bluetooth
  • Antworten:1
Robbiani Renato
  • Forum-Beiträge: 670
08.05.2022, 18:30:19 via Website
Hallo zusammen
In einem Buch habe ich ein Beispiel welches eine Socket Verbindung über Bluetooth macht. Leider kriege ich das Beispiel nicht zum laufen.
package ch.robbisoft.bluetoothchatdemo
import android.bluetooth.BluetoothAdapter
import android.bluetooth.BluetoothDevice
import android.content.pm.PackageManager
import androidx.appcompat.app.AppCompatActivity
import android.os.Bundle
import android.util.Log
import android.view.KeyEvent
import android.widget.*
import ch.robbisoft.bluetoothchatdemo.databinding.ActivityMainBinding
import java.io.*
import java.util.*
import java.util.jar.JarInputStream
import android.Manifest
import android.os.Build
import kotlin.concurrent.thread
private const val DEVICE1 = "..."
private const val DEVICE2 = "..."
private const val REQUEST_FINE_LOCATION = 321
private val MY_UUID = UUID.fromString("dc4f9aa6-ce43-4709-bd2e-7845a3e705f1")
private val TAG = MainActivity::class.simpleName
class MainActivity : AppCompatActivity() {
private lateinit var binding: ActivityMainBinding
private val adapter = BluetoothAdapter.getDefaultAdapter()
private var serverThread : Thread? = null
private var clientThread : Thread? = null
override fun onCreate(savedInstanceState: Bundle?) {
    super.onCreate(savedInstanceState)
    binding = ActivityMainBinding.inflate(layoutInflater)
    val view = binding.root
    setContentView(view)
    input.isEnabled = false
override fun onStart() {
    super.onStart()
    if( if (Build.VERSION.SDK_INT >= Build.VERSION_CODES.M) {
            checkSelfPermission(Manifest.permission.ACCESS_FINE_LOCATION) != PackageManager.PERMISSION_GRANTED
        } else {
            TODO("VERSION.SDK_INT < M")
            requestPermissions(arrayOf(Manifest.permission.ACCESS_FINE_LOCATION), REQUEST_FINE_LOCATION)
    }else{
        startOrFinish()
override fun onPause() {
    super.onPause()
    serverThread?.interrupt()
    serverThread = null
    clientThread?.interrupt()
    clientThread = null
override fun onRequestPermissionsResult(requestCode: Int, permissions: Array<out String>, grantResults: IntArray) {
    super.onRequestPermissionsResult(requestCode, permissions, grantResults)
    if (requestCode == REQUEST_FINE_LOCATION && grantResults.isNotEmpty() && grantResults[0] == PackageManager.PERMISSION_GRANTED){
        startOrFinish()
private fun startOrFinish(){
    if( isBluetoothEnabled() ){
        connect()
    }else{
        finish()
private fun isBluetoothEnabled() : Boolean {
    val enabled = adapter?.isEnabled ?: false
    if( !enabled ){
        Toast.makeText(this, R.string.enable_bluetooth, Toast.LENGTH_LONG).show()
    return enabled
private fun connect() {
    val myName = adapter?.name
    val otherName = if(DEVICE1 == myName) DEVICE2 else DEVICE1
    for( device in adapter?.bondedDevices ?: emptyList<BluetoothDevice>()){
        if(otherName == device.name){
            val serverSocketThread = ServerSocketThread(adapter, TAG, MY_UUID)
            serverThread = createAndStartThread(serverSocketThread)
            val clientSocketThread = ClientSocketThread(device, MY_UUID)
            clientThread = createAndStartThread(clientSocketThread)
            input.isEnabled = true
private fun createAndStartThread(t : SocketThread) : Thread = thread {
    var keepRuning = true
    try {
        t.start()
        Log.d(TAG, "joining " + t.name)
        t.join()
        t.getSocket()?.run {
            Log.d(TAG, String.format("connection type %d for %s", connectionType, t.name))
            input.setOnEditorActionListener{ _ : TextView?, _ : Int, _ : KeyEvent? ->
                send(outputStream, input.text.toString())
                runOnUiThread { input.setText("") }
                true
            while ( keepRuning ){
                receive(inputStream)?.let {
                    runOnUiThread { output?.appent(it) }
    }catch (thr : Throwable){ //InterruptedException, IOException
        Log.e(TAG, thr.message, thr)
        keepRuning = false
    }finally {
        Log.d(TAG, "calling cancel() of " + t.name)
        t.cancel()
private fun send( stream : OutputStream, text : String){
    stream.use {
        stream.write(text.toByteArray())
private fun receive(stream : InputStream) : String? {
    stream.use {
        val num = stream.available()
        if(num > 0){
            val buffer = ByteArray(num)
            var bytesToRead = num
            while (bytesToRead > 0){
                val read = stream.read(buffer, num - bytesToRead, bytesToRead)
                if( read == -1){
                    break
                bytesToRead -= read
            return String(buffer)
    return null
Die Wörter "input" und "output" bleiben rot mit der Meldung ich soll für sie eine Variable erstellen. Im Beispiel geht es aber ohne. Wie machen die das?
Die Imports habe ich alle überprüft. Auch in den build.gradle habe ich nach geschaut. Einfach nichts zum Importieren oder so was. Auch in der Klasse hat es keine Vererbung.
Wo liegt das Problem?
Gruss Renato
Beste Antwort
Robbiani Renato
16.05.2022, 21:30:47 via Website
Hallo zusammen
Ich habe das Problem viel zu weit gesucht.
input und output sind zwei Elemente aus dem Layout. Nun funktioniert es.
Gruss Renato
