- Forum-Beiträge: 215
07.06.2012, 17:02:29 via Website
07.06.2012 17:02:29 via Website
Omega v50.1 Jelly Bean 4.1.2
Based on firmware XXEMRG Android 4.1.2 (Date: 04/09/2013)
Omega v54 Jelly Bean 4.3 (im zweiten Beitrag zu finden)
Based on firmware XXUGML4 Android 4.3 (Date: 27/12/2013)
Hello everyone and welcome to Omega's Thread for Samsung Galaxy SIII
InsideOmega v50.1 Jelly Bean 4.1.2
Kernel Stock XXEMRG
Modem XXEMG4
Multi 131 csc set to EUR
efs Backup (added the option to create efs backup during installation)
Omegadroid Walk Bootanimation by Jorq1H and anbech
Omegas Emblem Shutdown Animation by anbech
Omegadroid wallpaper added in default wallpapers
Floating Omegadroids by NadMaj
Omega Files app
Omega Settings app
Busybox v1.20.2
SuperSU
init.d support without the need of a kernel that supports init.d
Aroma installer - Installation is fully customizable by user and there is options to install everything or remove all Bloatware - read here for more info
User can flash apps and bloat apps any time without the need to flash again the whole rom, (flashing the rom once is required)
Full Wipe option
Wipe cache partition automatic before roms installation
Wipe Dalvik Cache automatic during installation
Wipe preload partition automatic before roms installation
Google apps from Android 4.2:
Playstore
Gmail v4.2
Android 4.3 Camera with Photoshare
Keyboard Android with Gesture Typing from Android 4.2
Keyboard with Emoji Support from Android 4.2
Clock Application from Android 4.2
Omegas addon applications:
OmegaDroid - The official application of www.omegadroid.co
Es File Explorer (with great Root Explorer)
Hide It Pro
Download All Files
ZArchiver
FastDormancy Toggle for I9300 by gokhanmoral
Flash player Support
OnlineNandroidBackup credits to H3R3T1C and ameer1234567890
CPU Adjuster by bartito - xda thread
Accounts Sync Profiler by bartito
Recycle Bin by RYO Software
Xposed Framework Installer by rovo89 - read more about Xposed here
Removed:
Bloatware
Boot sound
Charger Connection Sound
AccuWeather.com logo from Lock Screen
Omega Settings:
Blocking Mode icon on-off
Ink effect on-off
Ink effect custom color selection
Auto Call Recording on-off for incoming calls
Auto Call Recording on-off for outgoing calls
Increasing ringtone on-off
Set End Call delay
Tw Launcher Wallpaper scrolling on-off
Tw Launcher Rotation on-off
Mods:
23 Toggle Buttons Mod - credits to lidroid and wanam
Reboot menu with Recovery and Download
Email with Exchange Security Disabled
All supported languages enabled
All supported languages for Samsung Keyboard enabled
Faster GPS lock
Modded YouTube by rolle (can download videos)
Join more unlimited contacts in the contact app - Get this from Omega Files
Note II POPUP Browser by raubkatze
Battery % mod
Completely Silent Camera
Hide sms from call logs
Multiwindow manager - (Can be uninstalled from Settings)
Enable Call Button In Contacts - available at Omega Files
No sms to mms conversion
Unlimited contacts to sms - mms
Enable sub Symbols on Stock Samsung keyboard
Added exit menu to stock web browser
Skip music tracks with volume buttons long press
Lock Device button on status bar next to clock - available at Omega Files
Samsungs Task Manager Shortcut app by indie
Media Scanner Fix - credits to shoman94
Fix the USB OTG Unmount Wakelock - credits to jazzk
crt-off effect - available at Omega Files
Tweaks:
build.prop tweaks
Stock Theme Changes:
Omega Theme for aroma installer by our artist anbech
Dithered Holo Background
Black status bar
Blues Circle battery % icons
Accuweather Widget transparent by raubkatze
Rom is Deodexed + Rooted + Zipaligned
Omegas Download Center
Omega v50.1 Jelly Bean:
Based on XXEMRG Android 4.1.2 (Date: 04/09/2013)
Modem XXEMG4
All mods from previous Omega JB 4.1.2 versions added
Rom is No Full Wipe
Installation:
GROSSER TUTORIAL GUIDE
Euer Phone muss Root Rechte besitzen. Wie das geht steht hier:
For Root read here
For CWM Recovery read here
Bevor ihr anfangt macht erst mal ein Backup eures Systems.
Dieses Backup auch Sicherheitshalber auf Pc abspeichern , falls was schief geht.
Wenn alles gesichert ist, gehen wir ins Recovery und machen folgende Wipes:
Wipe data / factory reset (Wird nicht benötigt, wenn ihr schon eine andere Omega Version drauf habt)
Wipe cache
Wipe dalvik cache
Install Omega
Omega Files application will be included in the next version Omega v4.0
Kitchen application - Customize your rom!
In Omega Files Kitchen you will find everything you need to build and customize your rom the way you like it.
Instructions:
To use Omega Files Kitchen you need Internet connection.
Browse Omega Files contents and download the files you want to your Device.
Files are downloaded in folder sdcard/download
Install the files using your favorite method.
Aways take a nadroid backup before installing files from the kitchen.
Contents:
work in progress......
Quelle : Org. Xda Thread
— geändert am 20.01.2014, 15:14:01
Grüßle, Haeretik Meine CM/AOKP Theme & Icon Packs
