So.. Die 13.1 ist draußen:
Based on firmware XXBLH3 Android 4.0.4 (Date: 21/08/2012)
Modem BWLH1
Kernel Stock XXBLH3
efs Backup (added the option to create efs backup during installation)
ClockWorkMod Recovery 5.5.0.4 v1.5 by Chainfire -(removed from v10)
CWM Manager v3.60 by Chainfire
CSC: BLF1 - set be default to EUR
Busybox v1.20.2
SuperSU v0.95
init.d support without the need of a kernel that supports init.d
Aroma installer - Installation is fully customizable by user and there is options to install everything and remove Bloatware - read here for more info
Wipe cache partition automatic before roms installation
Wipe Dalvik Cache automatic during installation
Wipe preload partition automatic before roms installation
*(removed)-Option to Full Wipe before installation in Aroma (this will only wipe data but not sdcard and extSdCard)
Applications:
All stock applications - plus:
Flipboard (updated to latest version)
Google Maps (updated to latest version)
Gmail (updated to latest version)
Play Store v3.8.17
S memo
Mods:
Customizable 15 Statusbar Toggle Buttons by lidroid - ported be wanam
Extended Power menu with Recovery and Download - available in Omega Files
Autobrightness is Fixed - available in Omega Files
Reduce Home Button Lag by wanam - available in Omega Files
Fix for cell standby issue
Battery % mod by pglmro
Disabled advertisements - Can be enabled again by flashing this CWM zip file: Enable_advertisements.zip
Faster GPS lock
Silent Camera
Shutter Sound menu Enabled to stock camera
Samsung Camera HX-MOD v1.45 by hyperX - available in Omega Files
TouchWiz with wallpaper scrolling by Toss3
Disable increasing ringtone in Phone
Call Recorder - credits to wanam
Hide SMS from Call Logs - available in Omega Files - credits to wanam
Disable Scrolling Cache
Changed Launcher Priority to 1
Faster home screen scrolling
Modded YouTube by rolle (can download videos)
CRT-Off+On
Email with Exchange Security Disabled (available in Omega Files)
V6 SuperCharger credits to zeppelinrox - with the option to enable and disable the script in Omega Files
Tweaks so memory will never go below 200 mb
Stock Theme Changes:
Dithered Holo Background added by Zabalba
Blue % battery icons
Blue Toggle Buttons
Omegas addon applications:
Es File Explorer (with great Root Explorer)
Hide It Pro
Download All Files
FastDormancy Toggle for I9300 v1.0 by gokhanmoral
Mount external microSD card as USB mass storage v1.2by Kopfgeldjaeger - available in Omega Files
Keyboard:
Arabic keyboard support
Chinese keyboard support - Chinese keyboard can be downloaded from Omega Files
Bloatware Removed
You can install them from Omega Files
Removed:
Boot sound - can be enabled from Omega Files
Plug in charger sound - can be enabled from Omega Files
Shutdown Animation - can be enabled from Omega Files
Rom is Deodexed + Rooted + Zipaligned
